Old Jul 22, 2015, 2:42 PM
Browse all: Wheels and Tire
245 vs 265 Tires
Old May 8, 2010 | 5:26 PM
iowa boy's Avatar
Default 245 vs 265 Tires
My factory LT245/75/R16's on my 2006 HD are ready to be replaced. Would like to upgrade to 265's. How much will this effect my speedometer and fuel mileage. Pull a horse trailer in summer to shows within a 100 miles. Will it pull better?? How about warranty?
Thanks
iowa boy
Old May 8, 2010 | 6:37 PM
LARIDERS's Avatar
won't be a big difference. but it will not pull any better. The taller the tire the more side wall there is to flex. the more flex, the more it will sway. should not be a whole lot in gas or speedometer. but the taller the tire, the lower it makes the gear in your truck.
Old May 21, 2010 | 11:18 AM
sbigshaun's Avatar
As well as the tire being taller, it will have more tire on the ground since it is a wider tire. The 265 is a good fit for the truck. I had them on my 99 1500 and my speedometer was almost dead on. So no need to worry with that. And as far as the sidewall flex, I don't think it will be that bad (I worked as a tire salesman for 3 years just before my wife was transfered to Cuba) but if it is something you are still worried about, try a load rage D or E tire. I would recomend the D, it'll give some stiffness without being as tough as the E.
Old May 22, 2010 | 7:08 PM
72c10gunn's Avatar
The bigger the better!
Old May 23, 2010 | 8:55 AM
SilveradoShane413's Avatar
265's on my 1500
Old May 23, 2010 | 10:03 AM
larryboy58's Avatar
My 04 came new with 235's from the factory and i went to 265/70/16, no noticable differance. Some where I read that there were 2 tire sizes available from chevy for the 04 235 and 265. So it worked well for me. 1 month ago I replaced the wore out 265/70/16 with 265/75/16, worst mistake i could have made. This time it threw the speedometer off 5 mph. I will not get into the other issues, but I hope this helps.
Old May 23, 2010 | 8:03 PM
Sirius018's Avatar
Ive got the 285/75/16's on my 04 and the only difference i have found so far is that speedo is 3 miles slower than actual speed but other than that my truck handles and pulls fine.
Old May 24, 2010 | 4:40 PM
wellmax's Avatar
when it was time to replace my tires (same size) my tire dealer told me not to go to the 265 tire size, said i would get better mileage with the 245 tire size.
so thats what i did and truck runs and drives good, for a 2500 series.
Old May 24, 2010 | 11:40 PM
therewolf's Avatar
Hi iowa boy,
Welcome to the Chevy Forums.
Those factory tires may be 10-ply E-rated radials. They came standard on many 2500HD models. You can tell if you look for the inflation pressure, it will be 80PSI max. If you have load range E tires, sidewall flex won't be much of an issue.
The wider (and at lower inflation pressures, for C&D rated radials, softer) tires will have a poor effect on gas mileage. You'll also notice a difference in tire performance when you tow, if you change from Es to a lower rated tire.
FWIW, I kept the same size and brand tires on my 2004HD when I changed to custom rims, because I liked the performance and longevity of my original E-radials. I thought 65,000 miles for one set of highway radials was hard to beat.
Old May 25, 2010 | 8:19 AM
2000sdime's Avatar
wow i didnt relize there was this much to consider on tires buuut anywayz ive got
my tires are mastercraft c/t's 265/75/R16 on my 95 k1500 and the speedo is dead on and im also runnin a 10in wide rim so im pretty sure you'll be fine with 265/75's and ive pulled trailors with boats on em and cars and tractors so i think you'll be fine haulin some horses
