Platform: L-Body
95 Corsica Engine Codes
Old Oct 23, 2006 | 10:18 PM
raysrestoration's Avatar
Default 95 Corsica Engine Codes
95 Corsica 2.2 4cyl . Is there a way to get engine error codes from turn-key ?
Thx
Ray
Old Oct 27, 2006 | 8:11 PM
ryanmetcalf's Avatar
Default RE: 95 Corsica Engine Codes
Well on the 1989 Corsica (6 cyl) I owned there was a way in which you could short two pin holes of your data connector (The propreitary GM one that came bfore OBD) and turn the key forward one position (pre-start) and it would flash your engine code light in a sequence similar to morse code. I only had to/needed this technique once, having not used it in a while, I'd reccomend talking to someone at AutoZone/O'Reilly/Napa/etc who has done this before.
Old Oct 27, 2006 | 8:15 PM
Ok, shortly after typing up my last reply, I found this:
https://chevroletforum.com/m_7464/tm.htm
"Is your engine light on? If so under the dash just to the right or left of the steering colum you have a plug/connector with nothing hooked to it. It may have a cover on it. It will be a 12 pin connecter. If you jump the top 2 on the right side, then turn the key on the light should flash once, long pause, twice short pause. That is a code 12, that means you are into the diagnostics, it will flash that 3 times, any code after is what is wrong. If you call Auto-Zone or Advance Auto Parts they should be able to tell you what the code means."
I would double check that your connector in your 1995 matches this one before attempting, but this is the technique I attempted to outline in my last post.
more information (from a 1990 Corsica) is also here:
https://chevroletforum.com/m_7081/tm.htm
rabbit0102030
S10 & Blazer DIY and Useful Threads
Mar 5, 2014 7:36 PM
Barclayd
Aug 6, 2013 7:55 PM
armymech666
Oct 27, 2012 1:36 PM
raysrestoration
Dec 30, 2006 8:58 PM
buijon
Dec 15, 2006 6:07 PM
