Tail lights
Old Aug 11, 2005 | 10:52 PM
Chevy99's Avatar
Default Tail lights
I have a 1999 Express 3500, extended 15 seater. I'm having a lot of trouble with the tail lights. Bulbs are all fine. Signals flash too fast, when the brakes are applied ,all the lights go out except for the back-up lights, which come on. I check all the bulbs and they are fine when I put them back in. A couple days later more problems occur. This is driving me nuts. Is there a harness ground or something that could be bad? I'm not impressed with the type of socket being used for the bulbs, is there a newer replacement socket I can use?</P>
</P>
Thanks for any help.</P>
Old Dec 21, 2006 | 9:22 PM
vinster888's Avatar
Default RE: Tail lights
i have an 01 and the dealer here had run a jumper ground wire for the brake bulb outside of the lens to a ground point. after i removed it i have intermittent problems like yours. so i am going to put the wire back. passenger side by the way
Old Dec 22, 2006 | 9:59 PM
golfer's Avatar
ORIGINAL: vinster888
Not a very impressive fix by the dealer ... but it seems to work.
Old Jun 8, 2007 | 3:05 PM
georgep14's Avatar
I had the same problem and fixed it the same way. I am having problems with my back up lights. I have a 99 s-10 and the back up lights won't come on when I throw it in reverse. Any help?
Old Aug 23, 2007 | 4:03 PM
jdonline
Guest
Posts: n/a
That sounds a little out of the usual. Is there no other way to solve that problem concerning the taillights?
Old Sep 3, 2007 | 8:52 AM
usanigel's Avatar
The problem is caused by a poor ground wire connection. Where this is is the tough part. Easy cure is to add a ground wire (common wire to all lights) from the light cluster to the van body.
PatrykKoul
Apr 26, 2023 9:14 AM
97 Tahoe "The Rig"
Aug 12, 2014 9:45 PM
hoghntr1987
Mar 7, 2014 11:22 AM
shanoahgood
Mar 20, 2013 10:45 PM
skdevore
Aug 26, 2009 10:18 PM
