Chevrolet Malibu
torque converter - question
Old Nov 17, 2006 | 4:15 AM
Skrappi69's Avatar
Default torque converter - question
Hi all.
IHA 97 Malibu 2.4L automatic. Once the tranny warms up it shifts really hard. Stalls at stoplights unless I put it in neutral. I had it put on a tester and it came back with "torque converter switch open". My mechanic said this is not a huge expense to replace the switch however I do have to watch the pennies. He said it was tricky to get at but could be done by me. Problem is, I don't know where that switch is located or how to replace it.
Any advice would be most welcome as this is my only car.
Thanks gang.
Old Nov 17, 2006 | 2:09 PM
uncle bill's Avatar
Default RE: torque converter - question
The torque converter has a lockup switch that locks up an internal clutch through a solenoid. If it's " open " then iy's in lockup. That would explain the stalling out. Kinda like letting out a clutch on a standard without giving it gas. Pick up a Chilton Repair Manual for that vehicle and it will explain how to change it and give the location.
Old Nov 17, 2006 | 2:17 PM
Skrappi69's Avatar
HI, yeah, that's more or less the problem; however, the Chilton’s manual only covers rudimentary drive train issues. It has a diagram of the function of a torque converter but no mention of the switch or solenoid to replace for this scenario. I have read some articles on similar cars stating there is an access plate that is removed and the switch can be replaced. That is the information I need. Where on a 2.4L 97 Malibu is the switch located and what do I need to do to replace.
Thanks by the way for the quick reply!
DavidC2015
Mar 12, 2015 3:49 PM
mikeryan
Oct 8, 2007 8:26 AM
qwilsvr007
Apr 29, 2007 1:24 AM
guessg
Jan 10, 2007 8:31 PM
ChevyMechaniac
Sep 12, 2006 2:38 PM
