Tracker 1989-2004
Platform: CAMI (Suzuki)
2001 tracker rear drum brakes
Old Nov 20, 2006 | 4:22 PM
aebig's Avatar
Default 2001 tracker rear drum brakes
does anybody know how to get the rear drums off a 2001 tracker? this is not the first time i've worked on a car and i cannot figure how to remove the drums.
i did the front disks, no problem.
Old Dec 7, 2006 | 10:54 AM
golfer's Avatar
Default RE: 2001 tracker rear drum brakes
https://chevroletforum.com/m_14479/tm.htm
Check this link ... apparantely there's two holes in the drum for metric bolts to remove the drums.
Old Dec 7, 2006 | 5:13 PM
SLJ2137694's Avatar
On my 2002 Tracker you have to use 2 8MM bolts and screw them into the 2 holes in the vertical surface of the drum. The bolts push on the axel and force the drum off. I can't remember if the bolts have a fine or course thread, sorry.
Old May 18, 2021 | 7:54 PM
Brettkb's Avatar
did they go right in? Or did you have to forces them In? because we cannot find out what thread pitch they are, we have 8mm, but don't know the thread pitch
Old May 19, 2021 | 7:03 AM
L84sky's Avatar
The 8 mm bolts have a 1.25 mm thread pitch.
The same bolts used to remove the rear drum (shown here) can also be used to remove the front rotor.
Old May 20, 2021 | 8:10 AM
Brettkb's Avatar
hello, thank you for answering, we have tried these thread pitches and they have not worked1.25
1.50
And 1.00
They thread only a few turns each, what other threads can we try?
Old May 20, 2021 | 9:00 AM
L84sky's Avatar
From the factory the drums are drilled and tapped for M8 x 1.25 bolts. It's possible someone forced a 5/16" (7.9 mm) bolt through the hole.
If that happened the correct metric bolt will no longer fit. Your options are to try a 5/16" bolt (either 18 or 24 threads per inch) or run a metric
tap through the hole and hope you can restore the threads.
Old Jun 1, 2021 | 5:10 AM
Brettkb's Avatar
Default Thank you
Hello again, thank you so much for answering, we were able to use the 1.25, threads were probably just rusty, but thank you for answering, because it helped us get them off.
Old Jun 1, 2021 | 9:25 AM
L84sky's Avatar
Thanks for the follow-up.
bushlander
Apr 5, 2021 9:59 PM
Tim Price
Mar 11, 2020 11:40 PM
Tim Price
Andy Talenda
Feb 18, 2013 7:12 AM
