Platform: B-Body
305 details.
Old Dec 8, 2006 | 12:59 AM
313hitman's Avatar
Default 305 details.
Im looking for details on a stock 92 tbi 305 engine in a caprice. my pops told me that the stock 305 tbi runs a roller cam but I wanna know for sure. plus I want to know if I can remove the A.I.R pump and put on some headers. thanks everyone...
Old Mar 11, 2007 | 3:38 AM
btotheh33's Avatar
Default RE: 305 details.
No it dont have a roller cam and you can remove the air pump and all the plumming.I did it but i didnt replace my manifolds with headers and i had to plug all the holes in the exhaust manifoldwhere the steel line went fron the A.I.R. system. I also remover my a/c and replaced it with an aftermarket pully from advanced auto that bolted right in place of a/c pump. I'll get the part number for the belt i used. I just routed the old one andpinched a vise grip on theslackand they matched one up for me.
Old Mar 23, 2007 | 2:52 AM
313hitman's Avatar
will removing the a.i.r systems cause the car to act different??
Old Apr 28, 2007 | 10:53 PM
countilaw's Avatar
Yes the 305 does have a roller cam. Removal of the air pump will not affect the running of the engine, but it will not pass emissions inspections, it will burn up the catalytic converter.
Old May 27, 2007 | 8:45 AM
1968 Pontiac's Avatar
I beg to differ on burning out the cat. My 92 chev K2500 truck with 305 tbi came from the factory without a smog pump. It just passed a smog test. That was with a brand new exhaust front to back, including headers, but the cat I removed was the factory original monstrosity, which would have been passing e-tests as long as we've had them here. Some of these trucks came with smog pumps and some didn't, but I don't know what the deciding factor was at the factory. But, a bad or removed O2 sensor will allow too rich a mixture to pass through the cat, causing premature failure of the cat.
kevinowen@tds.net
Traverse
11
Apr 23, 2021 9:21 PM
jivers12
Nov 13, 2008 9:31 PM
