Platform: L-Body
remove old cassette player '99 lumina
Old Dec 19, 2006 | 11:30 PM
fusionbiker's Avatar
Default remove old cassette player '99 lumina
I have a '99 lumina and I want to install a new CD player. I need to know how to remove the old cassette player. it looks like the front dash plate is in the way.
Old Mar 9, 2007 | 1:36 AM
matt2007's Avatar
Default RE: remove old cassette player '99 lumina
you need to pull the front dash panal off it is 1 panal from buy the head light swich to over buy the heater ac controuls it will just pull off you might have to remove the panale under the sterring colume cant remember once you have the pannal off which might be hard you will need to move gear shift lever down to 1 and be carful not to break any thing the raido is held in by 2 screw with 7mm heads to get your cd player in your dash kit might have to be worked with to get your front trim panal back on my scoshe kit stuck out a 1/2 in to far after puting it together so i had to cut the brackets and set the kit farther back in the dash when putting the trim pannal on be very carful and TAKE YOUR TIME it is a major bitch to get back on and your lever will need to be in 1 and wheel tilted all the way down GOOD LUCK I am really glad I put one in my lumina
golf_ne_1
Sep 28, 2009 7:55 PM
sadienrye
Mar 23, 2008 9:00 PM
CJC47
Feb 21, 2008 9:30 PM
EdM
May 23, 2007 2:14 AM
