S-10 & Blazer 1982-2005
trans filter
Old Oct 26, 2005 | 1:05 PM
awb81's Avatar
Default trans filter
I have a 2000, extended cab, 4x4; I am trying to change my transmission filter and am running into a few problems. The service manual says there is a drain plug for it, I've checked numerous times and have not found one. Also my shift cable bracket is bolted to the pan. It would not be a problem but the cable prevents me from getting to one of the bolts. The manual does not give a good discription of how to take that cable off. Has anyone delt with this or knows how to disconnect this cable? Also any other helpful hints for this project will be greatly appreciated.
Old Apr 18, 2006 | 3:03 PM
mxzeatr's Avatar
Default RE: trans filter
You can do it. You have to use a small wrench and turn it a quarter turn each time to get the bracket off. I did it on my 98. Do those first then drop the pan and dump the fluid...put a new filter on and your golden....took me about an hour to complete the entire thing! Good Luck!
Old Apr 22, 2006 | 2:40 PM
beavis's Avatar
a freind of mine has a gadjet with a long tube and a hand plunger (looks like a pump spayer ) puts the tube down the dipstic tube and sucks most of the trans fluid out of the pan and WOW less messy . it's nice to see people paying attention to their trans fluid ....my wife has a HHR it has NO dipstic and it takes dextron IV ..........wierd
Old Apr 22, 2006 | 4:34 PM
Nomad76lj's Avatar
i guess chevy must have faith in the dextron IV. is there a reminder light or somthing to tell you if the fluid gets low?
len24
Oct 14, 2014 9:36 AM
silverado 1500 2001
Sep 14, 2014 7:41 PM
DeHartShadow
Oct 22, 2013 10:52 AM
CACTUS24
Mar 28, 2012 8:26 PM
ukrkoz
Mar 4, 2012 3:16 PM
