K5 Blazer 1969-1994
Platform: Truck, GMT 400
1987 K5 BLAZER
Old Jan 6, 2007 | 12:49 AM
BLAZINGMONTESS's Avatar
Default 1987 K5 BLAZER
I HAVE AN '87 K5 BLAZER, IT'S BEEN SOUNDING LIKE IT WAS GOING TO STALL ANYTIME I APPLY THE BRAKES FOR A LONG AMOUNT OF TIME, SUCH AS AT A RED LIGHT I HAD THE THROTTLE BODY GASKET REPLACED AND NOW I HAD NO POWER WHEN I HIT THE GAS, AS MY FOOT WAS ON THE BRAKE THE ENGINE SURGED AND THE TRUCK JUMPED FOWARD A BIT, AND IT STALLED 4 TIMES IN A ROW AFTER EACH RESTART IT ONLY MADE IT ABOUT 4 OR 5 FEET. AFTER THE FOURTH TIME IT DIED, I TRIED TO START IT REPEATEDLY, BUT AS SOON AS I SHIFTED GEARS, IT DIED. PLEASE HELP!
Old Jan 25, 2007 | 4:42 PM
Fiesty96's Avatar
Default RE: 1987 K5 BLAZER
Fuel pump? Sorry....people here need more details than that. What other service and/or repairs have you had done?
Old Feb 19, 2007 | 6:18 AM
vandog's Avatar
sounds like when i blew a head gasket in my old truck
Old Mar 2, 2007 | 9:48 PM
2ndtime04gt's Avatar
Can you smell gas, like it was flooded? If so, you want to check the coil to make sure your getting enough spark.
Old Mar 6, 2007 | 11:31 AM
Tommygunz's Avatar
I had extremely similar issues with my 87 suburban, cheapest easiest to check is the fuel filter, about 8 bucks and 20 minutes of work, then pump.... then keep running the fuel and ignition systems. Doesn't sound readily like a spakr issue, but its possible. Good luck.
hokies2010
May 25, 2011 4:36 PM
CanJim
Jan 30, 2009 7:46 AM
CanJim
Jan 18, 2009 4:07 PM
Ryan Markt
Jan 28, 2007 9:39 PM
