K5 Blazer 1969-1994
Platform: Truck, GMT 400
HEATER PROBLEMS
Old Jan 18, 2007 | 2:25 AM
88BLAZER's Avatar
Default HEATER PROBLEMS
HAVING PROBLEMS WITH HEATER. OWNER BEFORE ME SAID HE REPLACED HEATER CORE. A/C WORKS BUT DONT BLOW THROUGH VENTS LIKE IT SHOULD . HEATER BLOWS COLD OR WHAT EVER TEMP. IT IS OUTSIDE.
Old Jan 25, 2007 | 4:32 PM
Fiesty96's Avatar
Default RE: HEATER PROBLEMS
Heater core isn't getting water circulating through it from the system or else it would adjust to whatever temp you want.Could be blockage to heater core. Does your heater core gurgle at all? When your heat level is on high is there warm water in the hose going to the heater core? I'd check the thermostat or if you even have one. Also when was the last time the whole system was reverse flushed and refilled?
Mom2ThreeACG
Traverse
Mar 12, 2018 6:20 PM
jteague
15
Jul 2, 2017 9:27 AM
mwehrste
Dec 29, 2014 11:19 AM
HHR Ratt
HHR
Oct 22, 2010 9:14 AM
DonGo
Dec 19, 2006 9:42 PM
