2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2001 impala
Old Nov 12, 2005 | 2:20 PM
pete28's Avatar
Default 2001 impala
Hello all, I just got my car about a week ago and I'm feeling like a slight knocking in the front end. I have no problem taking back to the dealer because it is still under warranty, but I was hoping to find a general idea of what it could be. It is not brake related because the rotors are brand new and the calipers are not sticking. It seems to be happening when I accelrate slightly or when i go around a gentle curve and have to cut the wheel slightly. at first I thought perhaps it could be a motor mount that might be loose but there is absolutely no knocking or anything when im simply cruising down the road. Also when Im at a stop, if I cut the wheel to either way, even slightly, it makes a knock that I can feel all the way down to the wheels. I had a couple of ideas of what to tell the dealer, perhaps a front end alignment is in order or possibly a loose or damaged part in the front end of the vehicle that could be causing it. I dont know if it matters or not but it is the six cylinder engine 3.6? Im still getting familiar with the car. I have to fix this issue before I can start adding some performance parts to the vehicle. Thank you for any help that might be offered. Pete
Old Nov 14, 2005 | 3:08 PM
Patrick's Avatar
Default 2001 impala
i would have them look at it..it could be something as simple as a dry joint.
Old Jan 9, 2006 | 5:55 PM
txroda's Avatar
Default RE: 2001 impala
I have the same car and had the same issue. It's a common issue with that car. It's the "intermediate steering shaft". First it was "lubed" and the problem went away for a year or so. Then it was replaced and the issue never came back. If it's still under warranty, you need to insist on replacement. GM is aware of this problem.
koobiidoobii
Aug 22, 2022 5:21 PM
Frank3
Dec 18, 2006 11:11 PM
bhaney987
Dec 17, 2006 11:20 AM
