Platform: Delta
Also Check out ChevyHHR.net
Old Jul 22, 2015, 10:54 AM
AIR FILTER REPLACEMENT
Old Jan 29, 2007 | 9:36 PM
CUTMAN100's Avatar
Default AIR FILTER REPLACEMENT
NEED TO KNOW HOW TO REPLACE AIR FILTER IN 2006 HHR 2.2. IF ANYONE COULD CAN EXPLAIN, IT WOULD APPRECIATED. THANK YOU CUTMAN100
Old Aug 29, 2007 | 8:03 AM
soflacopper's Avatar
Default RE: AIR FILTER REPLACEMENT
First off, Chevrolet onlyrecommends a 50,000 replacement of the air filter element. That doesn't make them right but they did make the car. If you're like me and feela need to check the element for replacement ... mine required it after 17,000 miles as the roads in South Florida are extremely dusty.
Now, since the 2.2 and 2.4 use the same filter element, I can only assume that your 2.2 replacement is the same as my 2.4
Steps:
1) Remove the lower clamp from the front rubber hose (air horn)
2) Pull up on the entire housing (gently but firmly ... don't yank it) and disengage it from the engine
3) loosen and remove the clamp to the flexible air intake hose on the right side of the engine (at the air cleaner side ince the hose goes through the wheel house)
4) With the air cleaner housing removed from the engine compartment, turm the housing over and remove the seven screws holding the lower part of the housing to the upper.
5) Remove and replace the filter element
6) Re-assemble in reverse order
silverado 1500 2001
Sep 14, 2014 7:41 PM
Copedawg
Uplander
18
Feb 11, 2014 6:26 AM
tcr1016
Jan 29, 2011 7:06 PM
Gaidin43
10
May 29, 2009 1:12 AM
clint59
Cobalt
Aug 24, 2006 5:14 PM
