Platform: Delta
Also Check out CobaltSS.net
Decreasing gas mileage
Old Feb 17, 2007 | 11:26 PM
slotcanyoneer's Avatar
Default Decreasing gas mileage
I own a 2005 Chevy Cobalt and I've had it since it was brand new. It has the 2.2 liter engine and about 23,000 miles on it. I have been noticing that my fuel economy has beengradually going down in the past few months. According to the digital fuel economy gauge it's gone from over 29 mpg to a little over 25 mpg and it is still going down. Are these gauges accurate? I try to keep my tires at the proper air pressure, change my oil every 3k, do all my maintenance,etc. I noticed it started going down after I had some work done to it(bad wheel bearing and brake pulsation). With the low mileage on it I doubt it needs a tune up. I was wondering ifa clogged air filter or fuel filter may be causing this problem although I checked my air filter and it looks fine. Any input on this problem?
Old Feb 7, 2008 | 12:41 AM
Razzy's Avatar
Default RE: Decreasing gas mileage
With 23,000 miles on it, a tune up couldn't hurt. When was the last time you had an oil change?
Old Sep 12, 2012 | 10:06 PM
granlund1's Avatar
What the "gauge" shows is the average fuel economy. The more you drive it (especially city driving) the more it will go down.
To get a better idea of the mileage you're getting at any one particular time, just re-set the gauge. To do this press and hold the reset button while the gauge is showing.
Hope this helps!
ahearnm
Mar 19, 2023 6:37 PM
NoMad7700
May 17, 2015 9:43 AM
ppg
Apr 29, 2013 6:29 AM
norrislaketn
Sep 22, 2009 10:19 AM
ourblackmad
Apr 29, 2008 1:35 PM
