Venture 1997-2005
Platform: U-Body
OIL IN OVERFLOW...INTAKE GASKET?
Old Apr 1, 2007 | 3:13 PM
98greenventure's Avatar
Default OIL IN OVERFLOW...INTAKE GASKET?
I have a 98 Chevy Venture and heard nightmares about the intake gaskets and headgaskets going bad. My heat sensor in the car doesn't work either. I have notice I have to add coolant all the time and there is either oil or dirty coolant inside. This is a 3.4 engine. Do I need to replace the intake gaskets? I have replaced the water pump already. If I have to replace the intake gasket, how hard is this? What are the torque specs? Any tips?
Jason
Old Jul 27, 2007 | 3:58 PM
asniff08's Avatar
Default RE: OIL IN OVERFLOW...INTAKE GASKET?
i had what appeared to be oil in my coolant resovoir for the 3.4l but it turns out it was mold that grew inside that looked like oil, you might have the same problem, i ended up having to flush the cooling sytem b/c it was so black from this mold
Old Jul 27, 2007 | 10:28 PM
golfer's Avatar
Mold than lives in antifreeze ??? That's scary.
If it were oil it would be cream colored scum. If the head gasket was gone you could see bubbles in the coolant usually caused by the exhaust stroke from the cylinder.
tommyxj2000
Apr 11, 2012 8:41 PM
Dads Toy
Oct 21, 2011 6:54 AM
samger2
18
Jun 2, 2009 1:47 PM
flash12
Dec 23, 2008 10:13 AM
gulfcoastjoe
May 4, 2008 12:38 PM
