Car dies when brakes are applied
Old Apr 2, 2007 | 12:25 PM
Celebwagon88's Avatar
Default Car dies when brakes are applied
Hi folks. Thank you for this forum! I just bought an 88 Celebrity wagon and I am happy with it except for the fact that it dies if I put the brakes on hard >< If I creep up to a stoplight slowly applying the brakes it will just barely stay running but if I put to much preasure on it dies every time. Any advice would be greatly appriciated.
Old Apr 2, 2007 | 6:51 PM
shnormo's Avatar
Default RE: Car dies when brakes are applied
Sounds like you have a bad torque converter. or a bad clutch
Old Apr 3, 2007 | 1:03 AM
YikesI hope its not the converter. Kinda hoping its a sensor but thats something I didn't think of. Thanks for the info.
Old Jul 31, 2007 | 4:11 AM
kc8zdf's Avatar
I had a 89 celeb and when I hit the breaks or soft whatever it would die as well. Come to find out is was the solinoid sticking in the torq convertor when down shifting. I ended up selling the car for 100 bucks and buying a s-10 4.3L vs truck. But I think thats was going on with yours..
Old Aug 1, 2007 | 2:35 AM
ammarfox's Avatar
Dear Celebwagon88,
I have the same problem and I solve it by replacing the ICV (Idle Control Valve). it is easy to replace and u can do it yourself.
Old Oct 3, 2007 | 7:49 PM
comingbackdown's Avatar
ORIGINAL: kc8zdf
Same thing happened with my dad's '85.
Quick solution for a busted Torque Converter Lockout Solenoid:
Find it, and unplug it. It'll drop your highway mileage a bit, but not enough to make your jaw drop.
Proper solution:
Scour the 'net or the junkyards until you find one cheap enough, and replace it. Problem solved.
Old Jan 8, 2009 | 11:16 PM
mmanter's Avatar
ORIGINAL: comingbackdown
ORIGINAL: kc8zdf
Proper solution:
I concur, as the same thing happened with the 85 my parents had. The car sat for about 6 months & I needed a car so I drove it for it to stall. I unplugged the torque convertor solenoid & all was well. I couldn't notice a fuel mileage difference in it at all.
Old Jan 13, 2009 | 11:25 AM
SFA Cobalt's Avatar
I duno sounds more like a leaky brake booster to me.
Old Sep 7, 2009 | 11:08 AM
kmksoulja's Avatar
i am having this same problem with my 1995 cheve lumina... it runs and stops fine for the first 30 minutes but then has troubles when stopping at a stop sign or even braking going around corners. but usually starts right back up after this happens. does anybody have the correct explaination for this?
Old Sep 9, 2009 | 9:27 PM
kmksoulja's Avatar
somebody told me it was the timing trigger? he seemed pretty sure about it.. what do you guys think?
