Go Back   Chevrolet Forum - Chevy Enthusiasts Forums > Chevy Trucks, SUV's, & Crossovers > Tahoe & Suburban
Old 05-02-2007, 01:38 AM
ksimmons95 ksimmons95 is offline
Default Daytime Running Lights 99 Suburban
New to the Forum. Tired of paying $80.00/hour. Myright side daytime running light is burned out. How do I replace? I tried unscrewing the grill and going in from the front with no luck. Should I remove battery and reach in from the back of the fixture? Thanks for the help.[8D] Register today for free or log-in if already registered to remove this ad!
Old 05-02-2007, 01:56 AM
RonH RonH is offline
Default RE: Daytime Running Lights 99 Suburban
In a 99 Suburban, don't the low beam headlamps double as the daytime running lamps?
Old 05-02-2007, 02:19 AM
I think so. I know the my brights work when I click the lever near the steering wheel. The lights below I think are for fog and they do unscrew from the front. Thanks
Old 05-02-2007, 01:30 PM
Don't know if I closed out this post by saying thanks at the end, but I still need help understanding how to change out the bulb in my right side daytime running lights! HELP HELP! [:@]
Old 05-15-2007, 12:09 AM
Fuory Fuory is offline
Yeah the daytimes are the reg running lights, you have to get at the bulb from behind the battery. So you may (trying to recall) have to remove the battery just to get the thing popped out to replace the bulb. It's a rather pain in the ass to change that ONE bulb but thats how you get at it.
__________________
99 Chevy Suburban K1500 LT 4x4
95 Mitsubishi 3000GT SL
94 Lincoln Mark VIII
72 Ford Mustang Mach 1
Old 05-15-2007, 09:43 AM
lost_in_alabama lost_in_alabama is offline
On the 99 Suburban, the low beam headlights are used as Daytime Running Lights. Starting with the 2000 models, the Daytime Running lights are separate from the headlights.
For the 1999 model do the following. Open the hood. There are two bolts holding the light assembly. Remove those two bolts, using either a 1/4 or 5/16 socket, and the light assembly will come out, which will allow you to access the bulb.
Tags
1999 , 2000 , 99 , chevrolet , daytime , drl , headlights , light , lights , problem , replacing , running , socket , suburban , work
HTML code is On
