99 tahoe reset passlock to restart fuel pump
Old Jan 22, 2006 | 6:03 AM
sbkmike's Avatar
Default 99 tahoe reset passlock to restart fuel pump
if you put wrong key in ignition, it kills fuel system, but how do you reset it?i undid battery,re hooked it up, it didn't help.
i checked fuses, all good
any help is appreciated.
Old Apr 22, 2006 | 4:42 PM
kjradio's Avatar
Default RE: 99 tahoe reset passlock to restart fuel pump
I have the same problem. Disconnecting the battery used to reset the codes, but not anymore. I don't know why it does this and wish there was some solution for Tahoe owners to reliably start their own cars! Does Chevy have any suggestions?
Old Apr 22, 2006 | 6:44 PM
Nomad76lj's Avatar
if u go to the help and suggestion center on the forum main page and read the 2nd post i think every thing raycorri@att.net has posted there should aply to your truck as well.
Old Apr 23, 2006 | 1:49 AM
viperjuice's Avatar
yo try this, when you go to start the truck, the security light will flash and the pump will shut off. leave the key on and if the light keeps flashing just let it sit for about 10 mins till the light stops, this should relearn you ignition. the reason ur heaving this problem is because the magnet inside the ignition pass lock module is junk causing it to send the incorrect info to the pcm
Old Sep 24, 2017 | 11:03 PM
Steven Taylor's Avatar
Default 1998 tahoe ignition fuel shut off issues.
Ok my 98 tahoe was recently stolen (f#%kin scumbags) anyways i got it back better than expected, worse than i wanted. The ignition is trashed like im hoping i wont have to but im reading about the fuel shut off security system. And since the ignitiin is basiclly ripped out. Am i going to have to replace the whole steering column?? And if this system works how the hell did they get it started when i cant. It looks like they used a screwdriver to start it. After they mangled it... Please help i cant really afford to replace everything.
viktoryakimov
Nov 3, 2023 3:30 PM
javen
Jun 12, 2011 4:37 PM
hunter10220
May 18, 2011 8:37 PM
bradlays
Jun 28, 2009 8:22 PM
