Front End Problems On A 95 3/4 Ton
Old Jan 23, 2006 | 1:26 PM
DM1975's Avatar
Default Front End Problems On A 95 3/4 Ton
Hello, I have a 1995 2500 Cheyenne that I just purchased and I noticed after driving it for about 20 minutes the front end starts to shake badly and the shake increases with speed, it also increases when I apply the breaks. I have had the front tires balanced and relubed the front end, could this be a problem with the breaks or with the tie rod ends? Or perhaps the steering box, I have no idea how to check these to see. If anyone could help I would appreciate it, thank you.
Old Jan 26, 2006 | 10:27 PM
DM1975's Avatar
Default RE: Front End Problems On A 95 3/4 Ton
No takers huh?
Old Nov 4, 2014 | 12:16 PM
mnolan78's Avatar
Sounds like a bad tire like a separated steel belt in a tire or warped brake rotors.
Old Nov 5, 2014 | 11:00 AM
SWHouston's Avatar
Nolan make some good points, and...
I believe I'd focus on Alignment, Tie Rods, Idler Arm or Ball Joints as well.
Get it checked/quoted by a competent FE Shop and get back to us.
Big_Ugly
Aug 20, 2013 12:12 PM
89silverado283
Feb 16, 2010 8:50 AM
nycac
Sep 16, 2009 5:02 PM
montana chevy guy
Aug 14, 2009 2:41 AM
