K2500 tire size
Old September 24th, 2016, 7:06 PM
Ian White's Avatar
Default K2500 tire size
Hi, wondering if anyone knows the largest tire you can put on 1994 Silverado k2500 reg cab.
I have 245/75/16's (6 lugs) but would like a bit more rubber for towing.
Considering the Goodyear Wrangler DuraTrac or similar but wondering how big I can go without a lift.
Anyone got numbers?
Thanks,
Ian
Old September 24th, 2016, 9:24 PM
burnhedge's Avatar
265 75 16 have worked without rubbing on all the k2500's I've had. FYI bigger tires are going to hurt towing more than help.
Old September 25th, 2016, 10:40 AM
Ian White's Avatar
Thanks burnhedge!
I tow < 10miles and deal with steep boat ramps so figured more rubber= more grip.
No real idea myself - am I just plain wrong there?
Also ,will 265's work on my standard rims or would I need new (wider) ones? - Again, total novice here!
Thanks again,
Ian
Old September 25th, 2016, 11:10 AM
97z71chevy4x4's Avatar
Generally speaking wider tire will give you better grip. I have 265 70 17 on my 97 (stock 2010 rims)
Old September 25th, 2016, 12:07 PM
burnhedge's Avatar
Originally Posted by Ian White
Thanks burnhedge!
Thanks again,
Ian
Just remember that a larger diameter tire will essentially give you a higher gear ratio. Some six lug 2500's had 3:42 if I remember right. Not real desirable for towing to begin with. As 97z71 said you may be able to go wider. I'd talk to a good tire shop to see what width will work with you rims.
