Tow Hitch Not Lining Up
Have an 04 Suburban 1500 2WD.
I have a class 3 hitch supposedly for this model. When I install it, the the bolts on either side on the frame line up great, but the two center bolts on the bumper are off by about 1/2 inch. My trailer is 4500 lbs with a 500lb tongue weight. Can I tow without these two center bolts attached? Do those two bolts make a big difference if I take it easy driving?
Is there a way to line these up?
thanks
thanks
Seriously? You mean the two bolts directly above the receiver, where all of the stresses will be concentrated? With a 4500-lb trailer?
You're really going to use something that doesn't fit right, instead of paying $150-$200 for a part made specifically for your truck?
