GMC savana 2007 not starting , not cranking over.
i have a GMC savana 2007 and recently it is not starting i change the fuel pump and right after i started to get that problem. well this morning it just not giving me power to crank over and i am in the mood to dump it , but i love this van, so please help, anyone.
No power to crank that is a battery problem, turn headlamps on, turn key to start do the headlamps dim. Is there any sound at all from the starter, ie solenoid click.
try jump starting from another vehicle. Does the engine turn over then, if it does not checkthe starter connections. If it does, get a new battery.
Take the starter out and take it to a parts store so they can test it. canucklehead has a good idea but having the starter tested will eliminate the starter if it's ok and point fingers at the safety switch. Also check connections at the starter and check the ground strap.
