Platform: Delta
Also Check out CobaltSS.net
Say for a month, now not starting!
Old March 26th, 2017, 1:23 PM
Farmblood's Avatar
Default Say for a month, now not starting!
OK I have searched and tried all so please don't blast me! My daughters cobalt is the dreaded 05. Would stutter now and then from the day I bought it (rpm would stutter, gauges would fall) but only for a second then good to go. Her first car so I said 'drive the wheels off it.' Got to the Eng. Pwr reduced/disabled messages and would die. Key off, 10 seconds, crank and go. Left car sitting one month during cold weather. Now car will start and within 5 seconds 'eng pwr reduced/engine disabled message.
I have;
Ran enough grounds to lightning proof a warehouse. Replaced MAF, MAP, crank sensors, ignition control module, plugs, and coil pack. Traced every wire I can find for possible shorts. No dice.
The only things I haven't replaced are the throttle body itself and the evap solenoid. I don't think this model has a secondary air injection pump. I can't find it anyway. Did switch the throttle body onto a running cobalt an it worked fine.
ANY ideas?? This little car runs amazing when it does run an I don't want to scrap it but I also don't want to keep beating my head and wallet against this wall
Old March 26th, 2017, 1:44 PM
Farmblood's Avatar
Default Also!
It throws a dozen codes but since the sitting I've not ran them. Ordered a little scanner so I'll post those codes when I have them. May be note worthy that holding the + and - battery cable ends together (unhooked of course) will no longer reset the computers/eliminate check engine light
Old March 26th, 2017, 2:25 PM
most power reduced messages relate to the drive by wire throttle system...throttle body or accelerator pedal position sensor.
see what the codes are and diagnose from there. probably will need a throttle body.
