radio size 2000 tahoe
Old Aug 19, 2007 | 10:51 AM
kevincw01's Avatar
Default radio size 2000 tahoe
I measured the factory radio and its 4x8". I read that 1 DIN is 2" so I think I need to replace it with a double DIN radio. But I'm noticing that places like crutfield are reccomending 1.5 DIN so now I'm now sure if double DIN is too large or if 1.5 DIN is just more popular. I'm looking for a radio that has built in sirius satellite radio. Also, if you know if there's a factory mod (like a newer model radio) that would fit into my tahoe(w/ sirius) that would be even better.
thanks
Old Aug 19, 2007 | 10:04 PM
Default RE: radio size 2000 tahoe
[sm=welcomesign.gif]to the forum. Try searching this forum as there are several threads that discuss aftermarket radio install.
Old Aug 19, 2007 | 10:27 PM
snomon's Avatar
Here's what I've learned when dealing with car stereo shops. Bypass the floor salesmen (who have a high turnover) and talk toa veteran installer in the back. They are a wealth of knowledge of what fits and what doesn't. I've found they know the specs better than the floor guys.
Old Aug 20, 2007 | 11:19 AM
rruelas's Avatar
The opening you have is 1.5 or 1 1/2 Din opening( 3 inch). The only radios that will fit without modification would be 1 din(2 inch) or 1.5 din (3 inch) radios. A 1 din radio will fit with a radio kit. A 1.5 din will fit without a kit.
A 2 din or Double din(4 inch) radio won't fit unless you modify the dash. Its possible to use the trim from a 03-06 Silverado or Tahoe so you can use a aftermarket, Double din radio. It will require you to lower the a/c controls slightly in order to have everything fit nicely. If you look on the web, you can examples of this.
Old Jan 5, 2008 | 8:30 PM
Jose13b's Avatar
hey did you just say that the bezel out of a 2003 will fit a 2000 because a want to put a double din in my surburban and I dont want to cut my bezel. anybody know where I can get a bezel cheap besides the dealer
Honda680
Mar 30, 2017 11:13 AM
elknose
Nov 3, 2013 7:55 AM
nerd160
10
Oct 19, 2012 9:31 AM
adamant
Feb 15, 2009 8:49 AM
