Chevrolet Malibu
1999 Malibu Turn Signal & E-brake Problems
Old Feb 28, 2006 | 9:53 PM
pwd's Avatar
pwd
Default 1999 Malibu Turn Signal & E-brake Problems
My 1999 Malibu 3.1l has two interesting problems. First the E-brake light/ beeper goes off randomly and secondly the turn signal flasher clicks randomly.
In terms of the E-brake light I checked the brake fuild and that seems to be up to the fill level and there is no problems with braking as of yet. I figure it must be the switch because for the last 2 years the E-brake light did not work at all. Now it beeps randomly. More over bumps and when you turn at speed. I was wondering how would someone get that the switch? Does the computer have to be taken out?
The turn signals are another problem. They work when you use the lever normaly and I check the light and they work. There is no burnt out lights and the clicking is at a normal pace. Although the flasher randomly clicks at a rapid pace. I heard there was a recall for this although the dealers around here say there isn't. I was told if the hazard flasher is replaced the problem would be solved. Although clearly that is not the case. The flasher still clicks randomly. Also note that when it clicks the turn lights do not go on.
I was thinking now it has to be a wiring problem or that the lever assembly is defective and/or needs rebuilding?
Any help would be greatly appreciated.
Eric
Old Oct 8, 2006 | 12:19 PM
golfer's Avatar
Default RE: 1999 Malibu Turn Signal & E-brake Problems
The brake fluid level switch is located at the master cylinder and sounds like the problem in this case.
The computer doesn't have to be touched for this.
The signal light issue is the multifunction switch , the lever on the left that's used to engage the turn signals, it's a common problem and needs to be replaced.
There was a recall for the hazard flasher switch but has nothing to do with this problem.
fishingpro77
HHR
Aug 4, 2016 12:44 AM
wceager
Oct 13, 2015 2:32 AM
wad5520
Dec 2, 2011 10:51 AM
RomanGuzi
Oct 2, 2011 11:40 AM
uncledewey
Oct 28, 2009 6:03 PM
