S-10 & Blazer 1982-2005
stalling s10
Old Aug 26, 2007 | 7:59 AM
chevymandan's Avatar
Default stalling s10
i have a 91 s10 with 4.3 v6 .my problem is i just changed the idle positon sensor as it was idling up and
down . Did the reset of the sensor at 40 mph . come home and parked it . got up the next morning for work , started fine then died . My idling problem is fixed but now it seems to be dieing on me after
i start it up or when i put it it drive or reverse. It also doesn't leave a code afterwards. cold this be the map sensor or the icm ???? Any ideas would be greatly app. thanks in advance
Old Oct 4, 2007 | 2:54 PM
sickvortech1's Avatar
Default RE: stalling s10
hello chevymandan, im a DYIer with a 99 4.3v6 sounds like a lack of fule pressure maybe, try to buy or
rent apressure gauge from parts store, there easy to use and sould help to yes/no fule issue. connect gauge to fule line-turn key to on- you dont even haveto start your truck-it should read 62psi or better.
if not it could be bad fule pump. like i said maybe.
Old Oct 4, 2007 | 2:56 PM
muddyblaze's Avatar
Does it shutter before it dies? When you put it in gear does it occur immediately?
Old Dec 12, 2007 | 8:10 PM
mastermosley's Avatar
does it stall when you give it gas or before then?
Old Dec 13, 2007 | 12:04 PM
bobbie95poca's Avatar
It could be the EGR valve. Mine was idling ruff now it has started dying when i have it in gear and am not moving.
epagidas
Dec 9, 2023 8:58 PM
slicedpi
Jun 13, 2023 9:45 AM
stonee2
Mar 16, 2011 7:33 PM
lwg660
Nov 28, 2009 11:34 AM
mthomp
Sep 15, 2008 10:42 PM
