S-10 & Blazer 1982-2005
S-10 Blazer Starting Problems
Old Jan 31, 2005 | 9:46 PM
quackpe's Avatar
Default S-10 Blazer Starting Problems
<TABLE id=HB_Mail_Container height="100%" cellSpacing=0 cellPadding=0 width="100%" border=0 UNABLE="on">
<T>
<TR height="100%" width="100%" UNABLE="on">
<TD id=HB_Focus_Element vAlign=top width="100%" background=" height=250 UNABLE="off">
I just finished doing a tune up on my 95 s-10 blazer and now it seems to have a hard time starting and once it does it idles very high around 3000, I tried to drive it and the transmission shifts are way off it wants to stay in third gear at 80 km and rev real high it will drop down a gear if i give it some more gas but when i let off on the throttle to cruise it down shifts and revs real high again </P>
</P>
any help yoou guys could give would be appreciated</P></TD></TR>
<TR UNABLE="on" hb_tag="1">
<TD style="FONT-SIZE: 1pt" height=1 UNABLE="on">
<DIV id=hotbar_promo></DIV></TD></TR></T></TABLE>
Old Feb 1, 2005 | 6:49 PM
akobak's Avatar
Triple check your firing order,(The order of your plug wires)and make sure the rotor is on all the way.
Old Feb 1, 2005 | 7:50 PM
RATMAN's Avatar
SOUNDS LIKE A VACUUM PROBLEM. A VACUUM LEAK WILL CAUSE HIGH IDLE, FUNKY SHIFTING, AND DIFFICULT STARTING. DID YOU REMOVE ANY VACUUM LINES? OLDER AUTOMATICS USED TO HAVE A VACUUM MODULATOR THAT WAS FED FROM THE INTAKE MANIFOLD. I DONT KNOW IF THEY STILL HAVE THAT, BUT I WOULDNT BE SUPRISED.<IMG src=smileys/smiley14.gif border="0">
Old Jun 27, 2005 | 2:27 AM
Fuel's Avatar
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
SymRealOnLoad = window.onload;
window.onload = SymOnLoad;
<FONT face="Courier New, Courier, mono" color=#0000cc size=4>What all did you do in the tune-up?</FONT>
Old Jan 31, 2006 | 6:24 PM
scmcketa07's Avatar
Default RE: S-10 Blazer Starting Problems
Check to see if your intake manifold is cracked. This could cause high idling and rapid gear shifting. I had the same problem on my 88 S-10. Also, check the vaccum lines as previously stated.
ray111379
Dec 14, 2008 8:16 AM
ray111379
Dec 11, 2008 4:28 PM
vhays
Apr 8, 2008 1:24 PM
djkrash
Apr 18, 2007 1:33 PM
