1988 Chevy Cheyenne fuel problem
Old Sep 7, 2007 | 5:03 PM
hairball's Avatar
Default 1988 Chevy Cheyenne fuel problem
Hello, I'm a first time poster here [8D] and I got given to me a 1988 Chevy Cheyenne(305) with a fuel problem. I got fuel up to the throttle body but thats as far as it goes no spray from the injectors. whats the best and cheapest fix ?
Old Sep 7, 2007 | 11:13 PM
golfer's Avatar
Default RE: 1988 Chevy Cheyenne fule problem
Are you getting spark?
Old Sep 8, 2007 | 4:09 AM
hairball's Avatar
Got spark[sm=shootshoot.gif]
Old Sep 8, 2007 | 8:12 AM
astroDZak's Avatar
Check for injector pulse with a test light at the clip on for the injector during cranking. If there is none my bet would be on the ECM needing replaced. Check your ECM fuses first.
Old Sep 9, 2007 | 7:19 AM
hairball's Avatar
OK, the fuel problem was the throttle body, So I purchase a replacement from Holley (670 CFM).
I'm also getting code 22 TPS circuit (signal voltage low)
Haynes says
Check for sticking or misadjusted TPS. Check all wiring and connections at the TBS and at the PCM.Replace TPS
TPS is new, all connection look good, but I will go over it again. I'm not sure but I think my 1988 doesn't have a PCM.?.
Old Sep 11, 2007 | 6:09 AM
hairball's Avatar
a local garage put the motor and distributor in and new throttle body on but they told me the throttle body was the wrong one for that engine so they put the old one back on, and then it didn't start...
so, I put the new throttle body back on and it started but I can't seem to get the idle down its real high ...
I was wondering if someone could tell me the position of the distributor rotor ? I know its to be pointing to #1, but in relation to the engine .
Old Sep 12, 2007 | 9:18 AM
hairball's Avatar
Thanks anyway I got things figured out
thatolflatbed
Oct 22, 2013 4:11 AM
Rogue92
Jun 15, 2013 10:54 PM
doster
Feb 16, 2013 4:06 PM
paulrbrown
Apr 13, 2010 7:23 AM
hairball
Sep 24, 2007 9:11 PM
