Platform: A-, G-, & W-body
98 monte front end noise
Old Sep 15, 2007 | 7:17 AM
spider626's Avatar
Default 98 monte front end noise
I have a 1998 monte carlo.When moving at 10mph or more around a right turn/curve I get a clicking noise.Anyone have an idea what it may be? or where i should start looking? Thank for any help you may give.
Old Sep 17, 2007 | 1:54 PM
BigBoom360ci's Avatar
Default RE: 98 monte front end noise
One of the CV axles needs to be replaced.
Old Sep 19, 2007 | 5:15 PM
spider626's Avatar
Thanks BigBoom. How hard of a job is this to do?never worked on a front wheel drive before
Old Sep 19, 2007 | 5:31 PM
Well you have to take your brake caliper off and undo you upper ball joint so it tilts out far enough so you can push the cv axle out of the hub. I forgot if ya have to remove the rotor or not but you will need a big socket for the cv axle nut i know for sure and possibly a hammer and some spray penetrant, needle nose pliers, another socket n a torx bitor allen wrenchi believe for the caliper bolts.
Brianabby88
Oct 15, 2011 8:39 PM
TASpinney9110
Mar 15, 2011 5:54 PM
mandrus
Mar 12, 2010 7:45 PM
slimnottygirl
Mar 7, 2007 4:40 PM
02TrailBlazer
Mar 14, 2006 2:28 AM
