'04 Silverado 6.0L starter issue
I have a 2004 2500 w/6.0L awd. I am about ready to put the 5th starter in this truck. <150k miles. The last one was brand new & last maybe 14-16 mos. Any ideas.
The main problems with starters not lasting is alignment to the ring rear, too much heat or poor power. Are you installing the starter yourself? I would make sure that the starter gears are aligned properly and that you have the correct shims. You may want to check with Summit racing for a new starter. I have had good luck with the powermaster starters.
2004 CHEVROLET SILVERADO 2500 Starters - SummitRacing.com
Good luck with the repair. Hopefully this one lasts longer.
freedomfighter_87
December 7th, 2009 7:32 PM
freedomfighter_87
December 3rd, 2009 6:30 PM
