06 silverado trans question plz help
i have a standard cab 06 silverado with a 4.8 and 4l60e trans .the truck has 67k miles .when i press the gas pedal like when im passing some one i cant get the trans to kick down even if i push the pedal to the floor ,but if i shift it on the coloum it down shifts fine . the fluid is in excellent shape the trans does nothing weird shifts smooth and down shifts smoth just under hard accelerating cant get it to down shift unless i shift it on the colum any advice is appreciated not sure if its electrical dont know were to start
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> pickawaykid,
Is this a regular or intermittent occurrence? Are you receiving any warning lights?
Louis
GM Customer Service
Louis
GM Customer Service
Official GM Rep
Someone stole your airbags? I recommend you consult with a certified technician. They will be able to offer additional information after inspecting the vehicle. I would also recommend having the airbags replaced.
Louis
GM Customer Service
Louis
GM Customer Service
shayandude
June 4th, 2022 4:10 AM
Jaccob
Silverado & Fullsize Pick-ups
February 12th, 2014 3:46 PM
Big tiny
July 28th, 2011 11:51 AM
Chevy-man
April 17th, 2011 10:50 PM
