'07 sunroof sun shade replacement
I have an 07 Silverado LTZ and it has a sun shade that slides under the sunroof, but it is like a mesh type material so the sun still shines through it. Does anyone know where i can get a solid sun shade for the sunroof?
My civic has the same thing and it drove me crazy if you buy one of the reflection things you put in your windshield on a hot day and cut it down to size And put the reflective side up It works well i even sewed a strip of fabric around the edge to make it look nice. if nothing else its a temperary fix until you figure something else
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> whitelightnin3006,
You may find the following sites helpful: GM Parts Direct: Your direct source for Genuine GM Parts or FN World Parts Center.
*General Motors neither endorses nor maintains these sites and will not be responsible for any of its contents.
Louis
GM Customer Service
Louis
GM Customer Service
carid
June 30th, 2015 6:11 AM
