Oil pressure at hwy cruise
Is it normal for oil pressure to move some when cruising at a constant speed? Mine rides between 40-45 doing 65-70mph. It's not a fast movement. It will be running at 44 for a bit then drop to 40 then a few seconds later will go back up to 44. Just seems to me that it should be at a constant psi cruising down the highway.
Hi tsduke.
Welcome to the Chevy Forums.
Between 40 and 50 is normal.
With most oil gauges, you can actually tell by the drop in oil pressure when you need your next oil change.
ps1588
October 14th, 2020 9:49 AM
drpepperporter
Silverado & Fullsize Pick-ups
16
April 2nd, 2013 11:05 PM
GTS 2.4
Camaro
April 15th, 2011 11:27 AM
