1989 K1500 4 wheel drive will not engage
Yesterday I shifted the 4WD to 2WD but it didn't disengage and I traveled about 10 miles before I noticed the light was still on. I stoped, backed up a few feet and the light went off. Today it will not engage and the light on the floor shifter is not coming on.
Where do I start to try and fix my mistake?
Thanks.
Thanks.
Thanks for the reply. It is a floor shifter and no play in linkage. I crawled under it yesterday and noticed that the passenger side cv joint is pulled away from the center chunck (pumpkin) not sure what you call it but it's out about 2 inches???
Definately fix the CV. How does the 89 engage in 4x4? Does it have a motor? Or is it mechanical?If it has a motor, that is probably where your problem lies.
My guess would be that you have a motor issue. The CV should not have anything to do with the motor engaging.I would get the GM part number and search for a GM or AC Delco part. This is not a good part to go aftermarket with.I have found a lot of parts by doing a google search for a GM part number.A lifetime warranty part looses it's appeal about the 2nd time you truck won't go into 4x4 when you need it to. Who cares if it's cheaper and they will give you a new one free when you're stuck?
SmittyNBama
Silverado & Fullsize Pick-ups
June 18th, 2011 11:25 PM
dylan13
April 13th, 2011 7:52 PM
