Notices
1990 Silverado Power Window Problems
Old November 11th, 2010, 3:47 PM
mchgnmike's Avatar
Default 1990 Silverado Power Window Problems
I have a 1990 Silverado that the passenger window quit working, thankfully it was in the up position. I changed out the motor/regulator with a new one and it still will not work. The window on the drivers side still works however.
Do I need to just trace the wires or is there a problem wire splice to look for? I appreciate any advice on this issue.
Old November 13th, 2010, 10:54 PM
suspect327's Avatar
run a wire from your battery straight to your window motor. if it works, then you need to replace your switch or trace where the problem is in between.
justin69
February 28th, 2015 2:54 PM
brian74montecarlo
April 14th, 2014 6:01 PM
julietta
February 9th, 2011 1:34 PM
davbell22602
March 10th, 2010 8:36 PM
Quick Reply: 1990 Silverado Power Window Problems
