Last edit by: IB Advertising
Browse all: Exterior Guides
- Chevrolet Silverado: Windshield Wiper Diagnostic
Guide to diagnose trouble and recommended solutions
1990 Silverado Wiper Problem
#21
Really????? How did you get the new one to work as a "direct replacement" without changing the wiper motor and connectors? I'd like to see a photo of this, and a description of how you did it! Cool!
#22
I have the same problem on my 89 K1500. Crazy wipers randomly pulse, run after turning them off, park anywhere and the washers don't work. I replaced the washer pump and it worked for about a month and quit. I'm thinking there must be an easy fix since nobody is responding.
Haner,
I ran the truck whilen it was raining yesterday & the wipers actually worked the way they're susposed to, and I have not smeared anymore grease in the plug. I'm still going to smear some more in there though.
#23
Sorry Haner & flh69 for my poor job of explaining what I replaced. I replaced the entire wiper motor with one that has the "new style" pulse module. It is a direct replacement and it was cheaper than repairing the old pulse module.
Does anybody know what year they changed the connecter on the instrament cluster? My 89 Silverado has a type of spade connecter that is a brass color. I got a cluster from a 93 but it has a pin connecter. I want to replace mine with a cluster that has the factory tach (I have a 5 speed).
#24
Hey, 8k15009, can you give a description of how you went about the wiper assembly replacement.... how long it took, where you got the parts, how much it cost, and a general description of the process? This would help those of us that still have the "bastard" mystery set up.
#25
[quote= This would help those of us that still have the "bastard" mystery set up.[/quote]
"bastard" is a correct name for what we have. It seems nobody else in the "whole wide world " has what we have.
#26
Sure Haner. Start by removing the wiperarms, then remove the cowl vent (that long black plastic that is under the wiper arms). Mine was a 3 piece assembly, the end pieces and the long center section. Be carefull not to break the long center section, Now you can disconnect the linkage from the wiper motor crank arm, there are two nuts for each arm shaft. Do NOT remove the nut and the crank arm from the wiper motor. Unplug the electrical connector from the pulse module. Remove the three wiper motor mounting bolts and pull the motor assembly from the cowl. Installation is reverse order. I did not time the proceedure, but would estimate not more than an hour. I just went to the salvage yard and picked up the wipermotor/pulse module assembly for $20.00. The assembly can fit from 88 through 98. It's a plug and play. Hope this helps you guys. Let me know how it goes.
#27
Thanks for the process description and other facts. Nice of you to take the time to write it out for us.
Since mine is still working well, I don't think I'll have to do this right away, but it sure will help to know what to do if I do need to replace it. And I'm sure this will help others as well.
Thanks again.
Thanks again.
#28
88 k2500 wiper and no washer problem too.
New member great site. Thanks for the pics Haner helped a lot.
Down to it. Have the park no delay most of the time problem and no washer! Tried the recall, dealer service tech bulletin 88-51 which is the bulkhead connector clean and re lube might be getting wet. No better.
Seen your post Haner and took the board out and clean and grease the blades on both side of the board. There is no pink cover on mine and under it is a coil and a set of points, cleaned those to. No better.
I put power to the washer motor and it works. I have the wiring diagrams so went under the steering column and opened the connector, white was the only wire hot key on and jumped to the pink going out and pump runs. On that connector going up to the switch is a jumper from the orange to the pink but only white, grey and purple go up into the column?
So is the orange wire the one that powers the pump, there is one to the wiper motor connector. Where is the wire that comes from the switch for the washer and does that mean that the board is bad?
Sorry for the long post and thanks for any help.
Bruce
Bruce
Donivan Deaton (September 11th, 2020)
#29
Hey Bruce,
Sorry for the delay in responding. I wish I could be of some help, but I didn't have to get into the wiring at all to fix my problem. Greasing the blades one time has continued to work for me.
I'm sure anything you figure out will be of help to the rest of us who own this strange wiper module configuration. If you find any answers, please post them.
Anybody else have any ideas on Bruce's dilemma?
Thanks!
Haner
Thanks!
Haner
#30
Thanks for the reply Haner.
I took the Delco part # from your pic and called Delco and they no long list that module only the c one.
Well drove it the other day short trip and the wiper seemed better, hope it keeps going.
As for the washer could not get it to work. For anyone else with no washer I wired a 15 amp fuse in line and a button to the pink wire on the plug under the steering column. Napa part # ech ws1049 pulled the pink jumper out on the 3 wire side and hooked the button to it just make sure your going out the pink wire on the mating plug which is the pump, works good. Did it to get them working as if I have to go to the new motor, module setup just need to plug it back in. Did not enough time to see if the orange wire just had no power or get into testing the switch in the column right now.
Thanks again.
Bruce
Thanks again.
Bruce
