Notices
Sponsored by: DashLynx
1991 Chevy Silverado knocking under load
Old March 26th, 2012, 11:51 PM
chickenfried209's Avatar
Default 1991 Chevy Silverado knocking under load
I have a 91 silverado tbi 350 4x4 with 128xxx miles, its all original just my work truck. My problem is that when i start the truck its fine no noise, engine runs healthy but once i put it under any load(drive) its starts knocking. it sounds like its coming from under the truck towards the tranny/motor or lower part of the motor. What im thinking is that maybe its not getting enough fuel when it has load so i was going to replace the injectors and fuel filter. im not trying to replace part after part and to get no where so if anyone can help or had the same situation some info/advice would be great, thanks.
Old March 27th, 2012, 5:24 PM
Gundog's Avatar
I would try setting the timing. These older trucks get loose in the timing gear chain. Try a few degrees more and see if that fixes the issue. Are ou running 85 octane?
Old March 27th, 2012, 6:37 PM
Allan In NE's Avatar
Fuel has't anything to do with it. If it's knockin', it's knockin.
Pull that converter cover and see if the converter bolts have worked loose.
How is the oil pressure?
Allan
Old March 28th, 2012, 1:31 PM
Gundog's Avatar
Low octane gas can cause knock and so can timing. Just trying to give some ideas as to what to check.
Old March 28th, 2012, 2:37 PM
Dunno, there's a huge difference between knocking and pinging.
Allan
Old March 28th, 2012, 7:20 PM
Gundog's Avatar
Allen has a point, but as it was not knocking when idling, I went with low octane fuel and timing.
Old March 28th, 2012, 8:09 PM
justimagination's Avatar
How's the oil pressure cold & warm ?
david
Old March 29th, 2012, 1:02 AM
thanks guys, tomorrow my buddy and i will check the timing, oil and each cyclinder compression test, also its more of a "knack" then a knock if that makes sense.
a guy at autozone said its a rod, ummm... im not best mechanic by far but wouldnt it also "knack" at idle?
Old March 30th, 2012, 2:41 PM
Chevy-Lover's Avatar
I just had the same prob with my 01 suburban (5.3 vortec).... it was the oilpump in my case. Had the sound only when driving at higher speed like on highways. But you could also notice it at the oil pressure. The different you could notice when you shift from D to N with a warmed engine at the gauge. It felt down to 1/4. Shifting back to D it was almost back to 1/2. That was still enough pressure to drive at usual city speed, but was to low at higher rpm like you got on highways... Had this problem with 148 miles.
Hope you'll find your problem!
Old April 3rd, 2012, 12:33 PM
ok so it ending up being the timing, it was advance past 8. how it got way up there i dont know. compression for all cyclinders but #3 and #5 were at 145 -150psi but #3 was at 70psi and #5 was at 80.
Quick Reply: 1991 Chevy Silverado knocking under load
