1992 chevy truck misses when it warms up
i have a 92 chevy truck with a 350..it starts and runs perfect when cold but when it starts to warm up and you give it gas it starts missing and backfires up through the motor..has new plugs, plug wires, and fuel filter
Try changing coolant temp sensor... located beside of thermostat housing.
This little sensor has all sorts of symptoms.. cost about 10 bucks.
Get it out of the equation. See if it helps.
changed coolant sensor didn't make any change...also forgot to add that after you drive it around and get it warm then shut it off its very hard to start...anyone know what else it could be...
harvester
Silverado & Fullsize Pick-ups
January 11th, 2015 2:39 PM
Dirtbike768
March 25th, 2009 10:51 AM
