Notices
1993 chevy 1500 hiccups when you accelerate.
Old June 8th, 2012, 2:47 PM
chevyman2727's Avatar
Default 1993 chevy 1500 hiccups when you accelerate.
Hi I have a 1993 chevy C1500 2WD 5.7L "350" that almost stalls when you hit the gas from a stop, but it seems to run fine as long as the rpm's dont drop below 1,500 I took it to a machanic and he said it was the pickup coil which I have now changed along with the fuel pump, fuel filter, distributor cap and rotor, and the throttle module on the side of the distributor. There has been no change in the problem although it does seem to come and go on its own one day it will be fine and the next I can hardly drive it. PLEASE HELP.........
Old June 8th, 2012, 3:06 PM
kevinkpk's Avatar
sounds to me like vacuum leak.
Old June 9th, 2012, 3:54 PM
Well that sound more accurate than what other people have said. So do you know how would I test the vacuum system?
Old June 10th, 2012, 7:24 AM
thonyyang's Avatar
maybe clean erg valve or make sure you don't have to replace it first before checking for leaks.
Old June 10th, 2012, 8:50 AM
kevinkpk's Avatar
I use WD-40 with it running, and hit vacuum connections or palces I suspect it could have a leak. If you hear the engine increase in rpm when you spray an area, that is where you have a leak. The egr valve cleaning is also a good idea.
Old June 10th, 2012, 10:03 AM
Doug Roberts's Avatar
Do not use WD-40 go get Carb cleaner or ethanol spray
he works on fords and can't even take a break off a Chevy lol
Old June 10th, 2012, 10:05 AM
Now that you got Carb spray clean egr and body assembly then look at TuneUp
dcnbre
February 18th, 2015 9:40 PM
cstephan5
July 21st, 2014 9:20 AM
NEsFinest
October 10th, 2013 10:34 AM
shadowbunny
June 18th, 2007 3:46 PM
Quick Reply: 1993 chevy 1500 hiccups when you accelerate.
