1993 Cheyenne K2500 6.5L Diesel Problem with Dash lights and gauges
My dash lights have finally stopped working properly after about a couple of weeks of it flickering between one set of dash lights to another set of dash lights. It looks like it switches to a different key mode but not sure. The blinker lights light up and stay solid the battery light is on and the check gauges light is on as well.
What is going on is that my dash lights that light up the gauges and the fuel, temp, battery, and a couple other gauges stopped working when the lights went out but when I flick the dim switch to the lowest dimmer setting my gauges all work again but that means my dash lights are completely out though. Any ideas?
Speedo works, exterior lights work.
I checked the fuses and have taken the switches out so far but I'm just an amateur and not sure if there is something wrong with them.
P.S. I believe this is a side issue but I thought I would mention it as well. I have the wiper switch spraying on my windshield when I just want to wipe not wipe and spray!
Any thoughts would be appreciated.
Thanks!
Thanks!
midnight1s1s
Sonic (Aveo)
July 28th, 2014 10:03 PM
silveradontn
Silverado & Fullsize Pick-ups
June 15th, 2013 10:11 AM
Big_Jazzer
February 27th, 2009 1:25 PM
