Last edit by: IB Advertising
Browse all: Powertrain Guides
- Chevrolet Silverado 2014-Present: Why Does My Truck Shut Off?
Guide to diagnose trouble and recommended solutions
1994 5.7 starts then stalls
#11
Same deal on my 94 k1500. Just bought it a week ago. 4k miles on rebuild. Engine tranny transfer case redone. Everything but the little things. Ran like a champ for a week then it started surging untill it stalled out on idle, especially if lights+turnsignals on. Unplugged IAC ran good for a day then back to the issue. Changed that out, it ran about 20 miles fine then, back to the same idle behavior. Noticed the rattle in the catalytic, changed it to magnaflow. Felt better driving, when in idle, same problem. Checked fuel pressure and it found to be low. Changing out fuel pump today. I'll update you after its installed.. In the end hopefully having all the little things updated also will keep this beautifull heap going another 200k miles.
#15
I have a 95 k1500 I will turn the key on and wait couple seconds and i'll hear a click in the dash and the gauges will come on then it will start fine ? is there a relay or something that would cause that?
#17
I got a 1994 chevrolet 1500 z71 has any of yall ran into the problem it will start run for a little bit but when you give it gas it dies out but if you constantly hit the gas it will run if you keep pushing it (letting off and pushing it again constantly) just put throttle body on module in the destributor ran down a few other things and its still doing the same thing any ideas??
Barry Guess (January 10th, 2020)
#18
#19
Did you ever figure out the problem?
mdm6713
Silverado & Fullsize Pick-ups
May 23rd, 2022 7:41 AM
streetterrorist
13
April 15th, 2022 1:42 PM
ShadeTreeJack
August 2nd, 2014 12:14 PM
Doug Wells 69
August 31st, 2013 12:54 PM
