1995 5.0L Miss firing???
I have a 1995 Chevy. I just replaced rotor and cap. Plugs wires and fuel filter. Truck idle fine for the most part. some times will die on its own.. not very much. But I have alot of carbon tracking on the plugs. Truck will go down the road sputtering and if i hold it to the floor it will gain speed but once i let out i cant hold speed unless im about 1/4 throttle it drives fine... But gaining speed is a big hassle. Some people are saying Fuel Pump. But I can smell unburned gas when im trying to pick up speed.. Someone please point me in the right way..... Code that came up are. TPS. MAP circut high. TCC and O2. Also did repalce the TB gasket. Was bad and had VAC LEAK!!
melat70
Silverado & Fullsize Pick-ups
July 31st, 2009 10:09 AM
