1997 1500 Silverado 5.7L Fuel pump ground wire help
I am replacing my fuel pump and I need help on finding out where my ground connects to on the frame. I accidentally disconnected it when putting the tank back in it has a connector on the end of it but I have no idea where the connection is on the frame it would help if anyone else has had this same problem or could offer a tip on properly grounding it to the frame and I don't have a soldering gun.
The ground is on the top of the frame if you pull the wire straight out from the pump to the frame and feel maybe 3 inches toward the front of the truck on top of the frame there is a little hole that has screw threads thats where its at you might have to wipe it down to find the hole though.
monkey23
Silverado & Fullsize Pick-ups
December 13th, 2012 10:48 PM
hunter10220
May 18th, 2011 8:37 PM
