1998 C 1500 4.3 vortec hard start - Chevrolet Forum - Chevy Enthusiasts Forums
Sponsored by: Bakliner
March 21st, 2008, 6:58 AM   #1
Hello,
When it is moist and 0 degrees celcius outside, my truck will only start after about 10 minutes of cranking.
The only thing I can do to prevent this is watch the weather report and plug in the block heater a couple of hours before I need it. It will start up fine after that.
Amechanic got a shock while placing his hand near the coil. Does this need to be replaced?
There is 308000 km on this truck and I bought it new.I am going for 1000000 km. that should take me about 23 years!
Peter
northey87's Avatar
Dayton PA
March 21st, 2008, 4:20 PM   #2
RE: 1998 C 1500 4.3 vortec hard start
Welcome to the forum!!! Don't know about the cold weather problem, but it sounds like like you have a potential short near the coil. Maybe just an exposed wire or something like that.
March 21st, 2008, 5:18 PM   #3
Thanks for the tip,
I should have said thatwhen it is well below the freezing mark, there is no trouble starting. There is only a problem when there is heavy moisture, near the freezing mark, and the truck has sat for 8 hours or more (overnight).
If there is a hard start in the morning, there is no trouble starting it after work.
I will check for a worn wire near the coil, but I did notice some rust on the coil mounting bolts. I have a replacement andI will change it anyway.
If that doesn't work, I guess I will have to keepthe block heaterconnected to the outlet. It seems to be the only treatment.
Thanks 87
April 14th, 2008, 11:31 PM   #4
I replaced the coil and now i am waiting for a rain.
Plugging in the block heater seems to be the best thing to help this truck start.
Peter
shawnvw's Avatar
Professional Mechanic
April 15th, 2008, 5:03 PM   #5
Definately sounds like a bad coil or ign wires. When it is moist outside, the spark will use the moisture as a path to ground instead of going to the spark plugs. start the truck, use a spray bottle and spray water on the wires near the plugs, and work your way up tothe the coil. When it starts stumbling\stalls, watch to see where the spark is coming from.
May 2nd, 2008, 7:46 PM   #6
It rained and there was no problem starting the truck.
The new coil makes the truck start and run like new.
I think I am saving fuel as well.
Sponsors
