Notices
1998 silverado makes chirping noise when air is on
Old October 12th, 2009, 1:41 PM
Kevinh111's Avatar
Default 1998 silverado makes chirping noise when air is on
Hey guys, in my truck (1998 Silverado) there is a very obnoxious chirping noise when the heater/vent/ ac is on. It only happens when it is on the medium or 3rd highest setting, and sometimes when on low. I dont think it ever happens when it is on the hi setting. It is not a big problem, just very annoying! It sounds like it is coming from on the passenger side somewhere behind/below the dash.
If anyone knows how to stop this noise from occuring, I would be very happy to hear a solution.
Old October 12th, 2009, 3:55 PM
Ride of the Month
May 2009
mudmaniac's Avatar
It's coming from your blower motor, my 95 does it when it's cold out but usually only on low speed. I doubt the motor can be oiled so you may need to replace it.
Old October 12th, 2009, 8:26 PM
Professional Mechanic
MDTAHOE's Avatar
You could remove the blower motor and spray it with lubricant but it will not last long. As MudManic said you should replace it.
Old October 13th, 2009, 4:00 PM
Ride of the Month
May 2009
mudmaniac's Avatar
Unfortunately almost all electric motors now come with permanently lubricated bearings, so as MDTAHOE said, spraying it may help for a little while but not for long.
Old October 13th, 2009, 8:40 PM
Kevinh111's Avatar
alright, thanks guys. Do you know the aproximate cost of a new motor? And how hard would it be to install?
Old October 13th, 2009, 8:45 PM
MDTAHOE's Avatar
Less than $100 probably less than $50. Very easy to replace. Pull the shield down under passenger side of dash if it has one(most likely held on by 7mm bolts). You will see the motor which is held in by three bolts.
Old October 13th, 2009, 8:54 PM
Kevinh111's Avatar
Thanks for the help! I'll havta pick one up within the next couple days
nytahoecop07
May 31st, 2021 1:42 PM
GreaseMonkey4x4
June 25th, 2012 10:01 AM
Jenkins
November 3rd, 2011 1:39 PM
valvano
June 29th, 2011 12:34 PM
dakine503
October 2nd, 2007 8:24 PM
Quick Reply: 1998 silverado makes chirping noise when air is on
