Notices
Sponsored by: DashLynx
2000 5.3L throws P0101 code
Old August 24th, 2011, 12:22 AM
jtlonghorn's Avatar
Default 2000 5.3L throws P0101 code
I've got a 2000 5.3 liter 1/2 ton. Was doing 50 mph down the road when I had a substantial loss of power to the point of doing 10 mph at 3/4 throttle. When I'd back off the throttle a bit, the engine would pick up and try and run...but only for a split second. Kept running real rough and with no power until I got home (5 miles).....even put it in neutral and gave it throttle with a real rough/inconsistant response. Turned the truck off when I got home, started it up and drove 5 more miles like nothing had ever happened.
Hooked up code reader a couple days later and it threw out P0101-Mass Air Flow sensor.
Would this sensor going bad cause the above symptoms?
I'd posted my problem pre-code last week and got a lot of solutions that were in line with a fuel pressure regulator problem.
Should I just replace the MAF sensor?
Thanks.
Old August 24th, 2011, 8:20 AM
kevinkpk's Avatar
Thanks.
Yes. If it does it again, shut it off, and unplug the maf sensor. If it runs better with it unpluged, the sensor has an issue. I'd use maf sensor cleaner before replacing it, that might be all it needs.
gearhead8853
Avalanche
June 28th, 2014 10:30 AM
gearhead8853
June 28th, 2014 10:29 AM
scrnchr
January 26th, 2012 10:43 AM
cham88
January 30th, 2011 11:48 AM
PastorK
March 21st, 2010 8:02 PM
Quick Reply: 2000 5.3L throws P0101 code
