Notices
Sponsored by: DashLynx
2005 Silverado stereo problem
Old July 3rd, 2012, 4:49 PM
Will Miller's Avatar
Default 2005 Silverado stereo problem
I have intermittent problems with the left front door speakers not working; when vehicle is cool after sitting out all night the driver door speakers won't work, then if it sits in the sun for a few hours presto, they work! the left rear always works and it doesn't matter if I'm on an FM stereo station or CD or AM Any Ideas
Old July 4th, 2012, 8:09 AM
Pull the door panel and see if the wire connector is tight and clean. Also check to see if the speaker is damaged in any way. Factory speakers are not very good and usually don't last very long.
Old July 5th, 2012, 12:31 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> There may be a wiring issue (connection, short, corrosion). Consider having the vehicle inspected by a certified technician.
Louis
GM Customer Service
davet
February 17th, 2022 8:08 PM
myoung84
February 2nd, 2018 8:50 PM
skidoofan
May 24th, 2009 9:28 PM
davidt18
December 26th, 2007 9:40 PM
Quick Reply: 2005 Silverado stereo problem
