2001 2500 4x4 6.0 engine swap
I see. To my knowledge, you can, in fact, put an 05 364 V8 into an 01. The frame brackets should be the same. I'm not entirely sure about the intake manifold though; if push comes to shove, you could transplant your old manifold into the new engine, therefore keeping the previous intake routing.
The only difference is you have a cable throttle body and the 05 has an electric throttle body. All you have to do when changing motor out is swap intake manifold, throttle body, injectors with fuel rails. Everything bolts right up though. I don't know if you have an EGR but if you do once again no problem just keep your exhaust manifold and it swaps over too. Transmission and frame mounts are the same, oh my crankshaft sensor was different but I had to just swap that over. I have a 99 5.3 and put a 04 5.3.
Peter M
Silverado & Fullsize Pick-ups
October 3rd, 2010 10:25 PM
stinemonster
May 30th, 2009 1:43 AM
huskersdomn8
February 22nd, 2007 11:23 AM
