Notices
2001 2500hd service engine light
Old October 15th, 2009, 9:53 PM
  #11
abergwi's Avatar
Default service engine light
MDTahoe, I got the shimms for the crank sensor. For one the sensor on the 2500hd is above the starter at the bellhouseing, so you have to take the starter off which is only 2 bolts and then a 10mm to get the sensor out. Getting the sensor out isn't as easy as you would think if you don't have small hands. I put one shimm on and it made it code earlier than it ever had so I put the second one on and it would hardly stay started so I just went and bought a new sensor for $62 and some change, put that in and haven't had a code since. Thanks for all the advice if I had to do it again I would just go straight for a new sensor, saves a lot of time crawling under the truck and racking your knuckles.
Old October 16th, 2009, 6:43 AM
  #12
Professional Mechanic
MDTAHOE's Avatar
They key to the shims was the warping of the plastic timing cover. Since your crank sensor was not in the timing cover that could not have been the problem.
Old January 22nd, 2015, 7:25 PM
  #13
bruzer's Avatar
I have a 04 silverado2500hd the engine light comes on flashing when reaching speed 65 mpg
Old January 25th, 2015, 4:55 PM
  #14
bruzer's Avatar
I have a 2004 Silverado 2500hd with the same problem im droping it off 1-26 Monday, you change the shim yet
islandarmor
Avalanche
315
September 24th, 2023 12:19 AM
enderst
July 27th, 2015 12:38 AM
lilrock
September 8th, 2009 9:09 PM
Deteoni
March 28th, 2009 1:39 PM
Quick Reply: 2001 2500hd service engine light
