2001 Chevy Silverado stalls - Page 3 - Chevrolet Forum - Chevy Enthusiasts Forums
Go Back   Chevrolet Forum - Chevy Enthusiasts Forums > Current Chevy Trucks, SUV's, Crossovers & Vans > Silverado & Fullsize Pick-ups
Log In
Search
Sponsored by: Bakliner
LinkBack Thread Tools Search this Thread
  #21
Old 06-08-2010, 03:01 AM
just watched the video wish i woulda know this before i dropped 400 damn bucks on a new fuel pump and crap uggghhhh damn silverados my dmax bever gives me issues but these 1999-03s have so many dumb issues freakin truck is nickel and diming me to death but thanks to everyone who is helping me fix it
  #22
Old 06-24-2010, 12:03 AM
Default 2001 Silverado stall
I own a 2001 Silverado 1500. I had a problem with engine stall and a rough idle on and off for several years. I was told everything from having a bad fuel pump to I was using the wrong plugs. I cleaned the EGR valve several times which usually helped. Recently cleaning the EGR stopped helping. I removed the throttle body and it was real dirty. I thoroughly cleaned it, and my problem appears to have been solved. The car is running like new again. The idle is smooth, no more stalling under load, and my acceleration is back to what it used to be.
  #23
Old 08-04-2010, 10:49 AM
I am glad if i helped atleast one person.. one of the forums i read a chevy mechanic suggested cleaning throttle body every other oil change..
  #24
Old 08-04-2010, 11:17 AM
I had simliar problems with my truck, it ended up being water in my fuel, it doesnt take much i could drive around all day and randomly it would just sputter and pretty much die if i touched the gas, then start right back up.
  #25
Old 08-11-2010, 11:43 PM
Quote:
Originally Posted by holyspatulaboy View Post
hey for theGenIII series check the throttle position sensor.. my truck used to boucne from 400 to 1000 rpms and my voltage would react accordingly...i also thought bad fuel pump/filterbut there is a bulletin out for idle problems but im not sure where it is anymorewhat they do is adjust your minimum idle air for the idle control and put a rubber plug in the butterfly...but what i do is every time i change my oil i pull off the intake tube and spray some throttle body cleaner up in the Idle control valve port and i have never had an idle problem since... i change my oil every 10,000 miles... so i guess if you use the 3,000 rule do it every 3 changes...
Experienced the same on my '03 4.8L... One $4 can of Throttle Body Cleaner and we're back to normal. Thanks for the tip...
John
  #26
Old 08-11-2010, 11:52 PM
Quote:
Originally Posted by Kogaborn View Post
ok, well, I told my mechanic about the fix holyspatulaboytold about. He had been playing for about a week trying to fix my problem and was severely stumped, so he tried it and poof, no more dieing. But there has to be a better way to fix this other than increasing the idle. I have thought about changing out the ECM, but I am not sure if that would be a solution or not. What would tell the motor to shut down if it falls below a certain RPM ?
It not that its being told to shut down, its the physics, at a certain RPM threshold the engine just can't maintain the momentum and it stalls... just like planes have to fly at a certain speed or they fall out of the sky...
Sounds to me the IAC Idle air control just got gummed up over time...running a fuel additive may help with this
  #27
Old 08-25-2010, 10:53 PM
fuel pressure regulator.......$80.00 autozone
  #28
Old 03-26-2011, 12:25 PM
Default Silverado stalling at idle
I have a 2003 silverado 1500 5.3 the other day i came to a stop sign the rpm were jumping from about 100 to 700 rpm than it would die. Its fine when im driving atleast 20mph but as soon as i let off the gas my rpm drop and eventually it stalls. It stalled 4 times during my 10 mile drive home from work and once again in my driveway. Ive been told a fuel pump or fuel filter wanted to get some other advice before i try that?
  #29
Old 03-26-2011, 01:39 PM
check for a vacuum leak with smoke machine or propane
  #30
Old 03-27-2011, 11:27 AM
Try cleaning the throttle body before you change the pump.
Similar Threads
Thread Thread Starter Forum Replies Last Post
2001 s10 stalls fekim S-10 & Blazer 2 01-07-2015 02:32 PM
2001 2.0l Won't Start, Or Stalls After Starting... johns2001tracker2.0 Tracker 1 02-04-2014 11:19 PM
2005 chevy silverado starts and stalls chevybuilder1989 General Tech 2 02-27-2012 02:42 PM
2001 2500HD stalls while driving oilyfishhead Silverado & Fullsize Pick-ups 0 04-01-2011 06:11 PM
2001 Cavalier Stalls, Quite the Story! bsimms General Tech 0 08-13-2008 10:48 PM
Tags
01, 1500, 2001, 2006, butterfly, chevrolet, chevy, doors, ecm, location, problems, silverado, stalled, stalling, stalls, start
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
