2001 V-6 Slow Cranking , Will Not Start ???
Battery Good , Cranks Slow , wants to cough through the Throttle Body , did this for a few days then started , seemed to Run Fine , now will Not Start , puff of smoke came out twice in back of the air filter to throttle body plastic cover , did not smell like electrical , symptoms to me it slipped time , maybe A fuel pressure regulator and Engine could be hydraulic-ing what do you think , thanks for any input and thanks for the use of this Forum.
Professional Mechanic
Low fuel pressure, weak spark or a flooded engine (from another problem) is the most likely cause. Jumped timing is possible but not nearly as likely.
I checked the Battery Cables today , at the battery and both connections at the starter and the ground , everything is clean , could the starter be bad? the starter engages the flywheel and the Engine turns over just slow , what other things can I check? thanks.
Geoffrey Dell
Silverado & Fullsize Pick-ups
July 13th, 2011 1:00 PM
wmmihail
April 20th, 2010 5:50 AM
rgnbull1227
February 5th, 2010 2:24 PM
silver911rdb
November 26th, 2009 8:06 PM
